Crv dpf pressure sensor
Hi I’m struggling to to figure out the inlet and outlet terminal on the dpf pressure sensor on my 2010 crv .. which is the inlet pipe the top or bottom on the mounted sensor
From this image which is the inlet and which is the outlet .. when engine is on the pipe on back has pressure front no pressure . Please if anyone can point out the inlet and outlet would be much appreciated
