 Honda HRV 2016 - Sat Nav just stopped working a few days ago - black screen only now.  No helpful info in the manual. Has anyone had similar problems & can it be reset?
If you have a GPS unit that is installed in your car's dashboard console, check to make sure the antenna is connected properly. If it is possible to move the antenna, try moving it to a different location that has a clear line of sight to the sky. Make sure the area you are in isn't obstructing the GPS signal.
  • 6 months later...
I have got a Honda HRV 2017. The satnav has stopped working. Went to my local Honda. They will not do it. If your car is five years or over I will not reset it. You have to do it yourself online which could cost you about £140.
