Hello, haven't owned by frv long, it's a 2.2 diesel. Garage said injectors were leaking so changed all 4, still the car will not start. If we spray easy start into it it starts right away and drives absolutely fine. Any ideas I would be very grateful
  • 2 months later...
FBogdan was awarded the badge 'Great Support' and 30 points.
Multiple causes:
1. Diesel fuel pump is broken
2. The compartment where is the diesel filter has a small dent and it gets fake air intake there.
3. Possible misfire from sparkplugs
Get a diagnosis, preferably with Honda HDS software.
More than likely this is an injector (or more than one) leaking back pressure when trying to start.
If the injectors are all ok, and have genuinely been replaced then sheck the pressure vavle on the end of the rail.
These can be bought for not much money and are easy enough replace with a long enough breaker bar.
