wondered if any one has a problem with handbrake . i have 04plate  have had new calipers, cable and shoes but does not hold very well on hills ajusted several times at the garage. when parked on a slope it sort of walks on stops when brick placed behind . any idea what problem os.
BAZZER RN 1 was awarded the badge 'Great Support' and 30 points.
Hi Kath
Had the same problem with mine when I bought it, There is a simple adjustment you can do yourself, Inside of the center console between the front seats ,remove the bottom cover, it just lifts out and you will see the handbrake cable with the adjustment nut, with a correct size spanner think its a 10 or 12 mm turn the adjusting nut a few turns to tighten the brake cable as advised in your Hand Book and this should solve your problem.
Best Regards
BAZZER RN 1
Hi Kath forgot to mention that my CRV is a 08 Reg and AWD but it should be the same to adjust  your Hand Brake, Have a look in your Handbook to see and let me know how you get on
Welcome to the Honda CRV Club Kath
Best wishes
BAZZER RN 1
  • 4 weeks later...
