BAZZER RN 1 was awarded the badge 'Great Content' and 30 points.
Hi Guys, If you have an Idling problem I have found a simple remedy which worked for me without having to use any tools
1. Make sure all car electrics are off
2. Turn the Ignition on and wait for 2 seconds
3. Turn Engine on and keep the RPM Revs at 3000 until the temperature reaches Max & the Cooling Fans come on
4. Once the Cooling Fans come on, lift off the accelerator pedal completely
5. Wait 5 Mins
This should fix the fluctuation and Idling Problem, The engine needs to be turned on & off a few times for the Computer to finish learning.
If the Idling is still too high turn the engine on & off a few times and wait a couple of minutes in between.
This method worked for my CRV and you should have a smooth Idle Speed of about 600-700 RPM.
Hope it works for you as it did for me
BAZZER RN 1
