On the hunt for N/S and O/S drive shafts.
Hi, I own a 2005 hinda frv. It has developed a persistent shake. So much so you can't see from the rear view. I've had the wheels checked for ballanced but the shake remains.
From what I've read, inner cv joint could be the issue.
I'm looking to replace both front drive shafts but I'm having a rough time try to track some down.
I'm hoping someone here might be able to point me in the right direction.  Also I've had fault code run to check for possible miss fire which was all clear apart from my persistent kick sensor fault code .
Hi Eddie, Welcome to the Honda Club, It might be that the only place to get the Drive Shafts is from Main Dealer as its a specialised fitment part, I will have a look around and see if any other Suppliers might be able to help and come back to you if I find out something to help.
BAZZER RN 1
Hi Eddie
Give , On line automotive ltd a try for the parts you need. Google their website or phone 01604- 806127 They have 85% off car parts which ends this weekend, I have used them before and always found them very helpful.
Its worth a shot
Best Regards
BAZZER RN 1
