Sounds like a classic case of DIY ingenuity! Sometimes it's those creative, "not by the book" fixes that end up being the most satisfying. Love the rubber grommet idea to keep it tidy—definitely a cleaner look than just Blu Tack alone. Bodgit solutions for the win! Regards: كارتي
Thankyou, although it doesn't answer the question about whether a full size wheel will fit in the wheel well. The dealer most local to me stated that one wouldn't fit, but I now know that not to be the case and a full size wheel will fit into the wheel well. Having just purchased the car I know little about them so far, but I seem to remember reading that the wheel well size was changed in 2018, so quite possibly a full sized wheel wouldnt then fit. -
