It's quite disconcerting to think that the dealers are confused about the update. Be interested to see where this goes
I trust my Honda Stream 2.0SE
Hi Adrian - welcome to the Club Wow! fabulous mileage for an old Honda, but that was back in an era when cars were made properly and lasted for years. I run a BMW Z3 which is 25 years old and 125k and have never really put a spanner to it in anger. Starts everytime and drives without any squeaks or rattles - a properly built car from that era. Great to have you onboard and feel free to post up some pics of the old girl - Earlier
