Hi guys, long time StepWgn owner here, and previous FN civic owner. Ive had an RG1 and it has never let me down but unfortunately powers outside my control have taken it off the road and thus I’m thinking of the later RK to replace it with… but see a lot with the CVT. Any CVT owners out there with a positive or negative experience?
