  4. Update to above, does the car charge when "Away" from home ok?
  5. Earlier
  6. Hi.....welcome to the Club Good to have you onboard!
  7. Thank you again, so much, for your help. I will contact them and hopefully get this part replaced for my mum. ironically, she is now thinking of selling her car and buying something smaller, so I will get this part replaced and then market it…. It’s far too good not to keep it going. Thank you again for your help, it really has been much appreciated. best regards Tina
  8. Is everyone with a EN:Y1 aware there is a software update at your dealer to update the charging of the vehicle, not sure what it is for exactly but getting it done this Friday. Possibly to cure faults arising following fast charge...
  9. The cases are just that and tend to fit quite well - it refreshes the external look of the fobs and usually has new rubber button inserts. Check the remote microswitches inside are secure on the circuit board as sometimes they detach and require soldering
  10. Its refreshing to hear good news about car dealerships as you don't often read too many positive reviews about them. Thanks for sharing with the club and glad it was all resolved at nominal cost to yourself
  11. Me and the missus have owned this car for 15 years, we bought it with 14000 miles on in 2010 and it was my pride and joy. We are moving to Devon in the next few weeks and unfortunately we have to let it go as its not really suitable for the local roads down there. This has been my wifes daily driver for the most part as I have a company car. Its done 97000 miles and been serviced every 10k (some main dealer when it was newer). Its had the transmission fluid changed and Ive recently spruced it up with replacement bumpers and headlight restoration. It has had some paint but in general its a really tidy example with none of the usual water ingress that seems to be common. Air con works but needs re-gassing. Absolutley bomb proof this car. If there are no takers on here its getting traded in for the wifes new car. Sensible offers please. Photos to follow. A chance to own a genuine low mileage 2 owner car thats been looked after and cared for. Its not been hammered or driven hard. I even put the original Bridgestone Potenza tyres on it until they stopped making them. Message me if youre interested. Cheers
  12. Hi all, Trying to find an aftermarket radio fascia for FRV but somehow I cant find anything, for a single DIN radio. What are you guys using please?
  13. Could the ECON mode or other settings be influencing this behavior?
  14. I have just brought NGK - Spark Plug - IZFR6K-11S what torque setting do i use on these?
  15. Bit of an update just got back from mr clutch there was air in the system from when the other garage changed the master and slave cylinders, they also said clutch was not worn like we got told wont be using them again happy with mr clutch drives good now shakes abit at idle think it could be spark plugs will have to look into those
  16. Good afternoon, I have a Honda Jazz 1.3, 2019 model. It's a lovely car, my 4th Jazz! Recently, the car has developed an issue with the steering, usually when the car is cold, such as first drive of the day. When I apply lock, there is a loud clunk which can be felt through the steering wheel. The more lock I apply, the worse it gets. Driving in a straight line, or with little lock, there is no problem. This issue seems to go away when the vehicle is warm. Naturally, I'm concerned as I feel this could be a serious issue. At first, I thought I'd run over a large stone or something, or uneven ground, that's how it feels. The clunk occurs in forward and reverse gears. Has anybody else had this issue and what was the remedy? Thanking you in anticipation, Des Roberts.
  17. have you tried ebay? https://www.ebay.co.uk/sch/i.html?_nkw=39680-TLO-GO1YB&_sacat=0&_from=R40&_trksid=p4582968.m570.l1313
  18. You can try on eBay (discount code at the top of the page) and still find Honda genuine fluids on there. I would definitely stick to genuine fluids if possible
  19. If the symbol disappears once you have the brake pedal depressed then no problem but if still illuminated then could be a faulty pedal switch - try pressing harder on the brake pedal as well
  20. Hi....welcome to the club Once Honda is in your blood you'll always come back to one.
  21. Hi, I have recently bought a 1994 Honda Accord Aerodeck cb9, is there anyone breaking one of these? Need the control unit under the front passenger seat. TIA, Majid.
  22. Thanks. Will give the differential fluid a go and if clutch maybe time will tell.
  23. Members Very sad to have to let my CRV go. Petrol, auto, 2002 183,000 miles £250, been in the family from new..The cat was cut out/stolen while parked. Most times she passed her MOT first time and very sad to see her go. No MOT and not taxed. She would need to be towed or put on a trailer. Location Sutton Coldfield, West Midlands.
  24. Thanks have now turned the warning message on
  25. Thankyou, although it doesn't answer the question about whether a full size wheel will fit in the wheel well. The dealer most local to me stated that one wouldn't fit, but I now know that not to be the case and a full size wheel will fit into the wheel well. Having just purchased the car I know little about them so far, but I seem to remember reading that the wheel well size was changed in 2018, so quite possibly a full sized wheel wouldnt then fit.
  26. the belt will gradually 'walk off' the pulleys if misaligned
  27. Trevor
    Dreams
  28. Hi guys, long time StepWgn owner here, and previous FN civic owner. Ive had an RG1 and it has never let me down but unfortunately powers outside my control have taken it off the road and thus I’m thinking of the later RK to replace it with… but see a lot with the CVT. Any CVT owners out there with a positive or negative experience?
