  2. So are the dealers, they confused too. As stated...
  4. Hi everyone i have finally joined a motorcycle club even though i have been riding since i was 16 i am now 60 i currently own a Honda cb400f 1976 and before that i have owned a couple of HONDA CB550 but i am having some running issues at the moment with the 400 will not idle off the choke i have stripped and cleaned carbs checked and adjusted the tappets and it has electronic ignition it runs like crap i am thinking it needs top end freshen up any thoughts if anyone lives in Didcot oxon and knows their way around the old Hondas their help would be welcome
  5. Earlier
  6. Hi, this question relates to a 2003 Honda CRV Initial apologies as this question, in various forms has appeared before but I have tried all the solutions suggested. Occasionally I have had to change the battery and once reconnected I have all sorts of issues with the alarm going off. Normally I have found that messing with various things like using and holding the key in the door lock causes the frequency of the alarm going off to decrease till once the intervals exceed 2 min, then the alarm stop completely. Currently, after replacing the battery, the alarm only goes off if I lock the door (using either the key or the fob). Leave it unlocked and it’s fine. Three questions, is there a way to reset the alarm, and secondly, if all else fails is there a fuse i can pull and finally the nuclear option, is the horn the same as the warning horn, if not what wires can I cut. All responses appreciated
  7. Hi there, I'm selling my much loved DC5, it's absolutely stunning and if you're in the market for a DC5 I strongly expect this is one of the very best out there. I really want the car to go to another enthusiast, someone who will look after it as well as myself. https://www.pistonheads.com/buy/listing/18463363 Thanks for looking.
  8. Just for info, purchased a steel wheel and tyre from The Wheelshop in same size as OEM. It fits into the spare wheel well fine, but only just height wise.
  9. Hi Philip My experience has been "HONDA THE POWER OF NIGHMARES" I bought my new e:NY1 on 30th September 2024 from Virtu Honda Stockton all excited with my new electric car. I was expecting not 256 as advertised but 200 miles range, as discussed with the salesman, which I would have been happy with. The first charge at 100% range was 148 miles 2nd charge 156 miles, to ensure the range was correct I had to drive with no heater no radio and at around 60 miles an hour in eco mode to get the 156 miles. I took it back and was told it would improve with use. As I am sure you will have guessed, it never improved. I asked Virtu Honda Stockton to test it and dropped it off 31st December 2024. I will not go into the details but on the 8th April 2025 they informed me that the car was ready to pick up, yes four months later. I advised them I wanted a new car as they had had the car longer than I had. I don't know what they have done to the car over the four months, they will not tell me. Virtu Honda Stockton admit they have had the car for an unreasonable timescale, and that they feel I should be given a replacement new car, but Honda UK say that I should pick up the car as four months is a reasonable timescale. I have refused to pick up the car until I get a full report on the work carried out and will then be going to the Motor Ombudsman service. Virtu Honda Stockton have at least tried to help, but Honda UK have been horrendous. I would recommend if you want to try an electric car keep away from Honda at all costs.
  10. Update to above, does the car charge when "Away" from home ok?
  11. Hi.....welcome to the Club Good to have you onboard!
  12. Thank you again, so much, for your help. I will contact them and hopefully get this part replaced for my mum. ironically, she is now thinking of selling her car and buying something smaller, so I will get this part replaced and then market it…. It’s far too good not to keep it going. Thank you again for your help, it really has been much appreciated. best regards Tina
  13. The cases are just that and tend to fit quite well - it refreshes the external look of the fobs and usually has new rubber button inserts. Check the remote microswitches inside are secure on the circuit board as sometimes they detach and require soldering
  14. Its refreshing to hear good news about car dealerships as you don't often read too many positive reviews about them. Thanks for sharing with the club and glad it was all resolved at nominal cost to yourself
  15. Me and the missus have owned this car for 15 years, we bought it with 14000 miles on in 2010 and it was my pride and joy. We are moving to Devon in the next few weeks and unfortunately we have to let it go as its not really suitable for the local roads down there. This has been my wifes daily driver for the most part as I have a company car. Its done 97000 miles and been serviced every 10k (some main dealer when it was newer). Its had the transmission fluid changed and Ive recently spruced it up with replacement bumpers and headlight restoration. It has had some paint but in general its a really tidy example with none of the usual water ingress that seems to be common. Air con works but needs re-gassing. Absolutley bomb proof this car. If there are no takers on here its getting traded in for the wifes new car. Sensible offers please. Photos to follow. A chance to own a genuine low mileage 2 owner car thats been looked after and cared for. Its not been hammered or driven hard. I even put the original Bridgestone Potenza tyres on it until they stopped making them. Message me if youre interested. Cheers
  16. Hi all, Trying to find an aftermarket radio fascia for FRV but somehow I cant find anything, for a single DIN radio. What are you guys using please?
  17. Could the ECON mode or other settings be influencing this behavior?
  18. I have just brought NGK - Spark Plug - IZFR6K-11S what torque setting do i use on these?
  19. Bit of an update just got back from mr clutch there was air in the system from when the other garage changed the master and slave cylinders, they also said clutch was not worn like we got told wont be using them again happy with mr clutch drives good now shakes abit at idle think it could be spark plugs will have to look into those
  20. Good afternoon, I have a Honda Jazz 1.3, 2019 model. It's a lovely car, my 4th Jazz! Recently, the car has developed an issue with the steering, usually when the car is cold, such as first drive of the day. When I apply lock, there is a loud clunk which can be felt through the steering wheel. The more lock I apply, the worse it gets. Driving in a straight line, or with little lock, there is no problem. This issue seems to go away when the vehicle is warm. Naturally, I'm concerned as I feel this could be a serious issue. At first, I thought I'd run over a large stone or something, or uneven ground, that's how it feels. The clunk occurs in forward and reverse gears. Has anybody else had this issue and what was the remedy? Thanking you in anticipation, Des Roberts.
  21. have you tried ebay? https://www.ebay.co.uk/sch/i.html?_nkw=39680-TLO-GO1YB&_sacat=0&_from=R40&_trksid=p4582968.m570.l1313
  22. You can try on eBay (discount code at the top of the page) and still find Honda genuine fluids on there. I would definitely stick to genuine fluids if possible
  23. If the symbol disappears once you have the brake pedal depressed then no problem but if still illuminated then could be a faulty pedal switch - try pressing harder on the brake pedal as well
  24. Hi....welcome to the club Once Honda is in your blood you'll always come back to one.
  25. Hi, I have recently bought a 1994 Honda Accord Aerodeck cb9, is there anyone breaking one of these? Need the control unit under the front passenger seat. TIA, Majid.
  26. Thanks. Will give the differential fluid a go and if clutch maybe time will tell.
  27. Members Very sad to have to let my CRV go. Petrol, auto, 2002 183,000 miles £250, been in the family from new..The cat was cut out/stolen while parked. Most times she passed her MOT first time and very sad to see her go. No MOT and not taxed. She would need to be towed or put on a trailer. Location Sutton Coldfield, West Midlands.
  28. Thanks have now turned the warning message on
