1998 Civic Aerodeck 1800 VTI
Preventative Maintenance
what is this? 2024 model
Foster33 joined the community
Who remembers these?
Many thanks for the advice, the garage have sourced a new one so at least the car is still on the road. Is it alright to ask peeps what they think it might be worth if I were to attempt to sell it? Mum bought in new in 1998, 105k on the clock now and well looked after. Hope this is ok- Earlier
Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? ThanksTyredguy started following Need to replace the Fuel Preasure Regulator & SensorTyredguy joined the communityMike Kingfisher joined the community- Dim low beam
I have a 2018 crv, currently has 62000 miles. I've never been pleased with the low beam brightness. Its fitted with H11 55 watt halogen bulbs which look OK. Looking online I can upgrade to H11 exeon or H11 LED's, but both seem to be 60 watts, and a huge amountof lumins more. I don't want to dazzle on coming traffic but I do want to have brighter lights without having the need for adaptors. Has anyone changed/upgraded their lights. Alternatively is new halogens the solution? I've fitted blue bulbs in the past which I didn't think made much difference. Full beam is fine.- Remember this?
Hi @Maurice j I have attached a PDF for you to look over to do some checks for your locking issue. Honda_eNy1_WalkAway_Lock_Troubleshooting.pdfSteve started following Lock and walk away function on Honda Eny1- Lock and walk away function on Honda Eny1
I recently bought my Eny1 ,,,which I absolutely enjoy driving I noticed that the lock and walk away function was not working ... it locks the boot but not the car and both Honda tech support and my Honda dealer agree that it should but cannot resolve the problem Does anyone else have this problem? Maurice
