things seemed so much easier back in the day - as long as the tyre was round then it was fine š
bignappa joined the community
GazB joined the community
CheScot joined the community
Finally found the problem. It was my passengerās rare ABS sensor, which had debris and was cleaned properly. All warning lights never came back. -
Thanks š expensive though
Hi, I recently changed my Honda civic 2020 battery and after some hours my Amber warning light pops up so I took it to a battery specialist to make sure the battery was a good fit and all seemed fine so I was then advised to remove battery connections for 10 minutes so it restart everything things but Amber warning light still pops up at random but car seems to drive pretty well and Iām worried whenever light comes on -
Frank419 joined the community
Rev Tony joined the community
