Z-Man98 joined the community
Mogweb joined the community
Gordy19 joined the community
Maarten joined the community
dearne75 joined the community
Angelov joined the community
If the symbol disappears once you have the brake pedal depressed then no problem but if still illuminated then could be a faulty pedal switch - try pressing harder on the brake pedal as well
