Balstel joined the community
mikemole joined the community
Springer joined the community
Brian M joined the community
Penelope joined the community
Dunc joined the community
Liz joined the community
cp140 joined the community
Finally found the problem. It was my passenger’s rare ABS sensor, which had debris and was cleaned properly. All warning lights never came back.
