  2. Hi....welcome to the Club There are still a few Aerodecks around but not many on the road. Spare parts especially panels are becoming harder to source but mechanically they are usually reliable as were most of the early models.
  3. Yesterday
  4. Steve my son...... the world is your Lobster
  5. Last week
  6. I am of age to 100% understand that... hit im terry 😂
  7. Arthur Daley is alive and well........ another nice little earner for her inddors Terrnace ny son !!
  8. Steve replied to Alan gsd's topic in The Lounge
  9. I had this with my wifes Yaris. I asked for the service history and it only had the one thing on it, but it did have a stamped book in the car. 6 months later i asked another branch of the same group, and it had an air-con fault reported but not resolved, air con still works but slightly noisey for past year. I was well annoyed and he moved on so i could not bollock him for it. Now have even lower trust in dealers now. To be honest £950 is not a lot and would not have any affect on the car, the car has not been written off (maybe you should check with carvertical) I recently had a bumper replacement because a fox ran in to it at full pelt. needed a whole new bumper. did not affect the rest of the car at all. If it was a category right off then they would of had to tell you. Best thing is to say it had a replacement bumper, be honest up front. People tend to not worry so much if your are straight upfront. Oh yes they were slightly dishonest for hiding it.
  10. Alan gsd posted a topic in The Lounge
  11. Hi all.I have just asked to review the service history for my Honda Jazz 2023 purchased Oct 2024.The history has that it had body repairs to the value of £950 only done a few days before purchase & a bumper swap a few days after my deposit was paid.Not a word was said about this.Has the Honda garage got the right to hide these details from me?I am now selling the car but obviously have to provide the service history for my p/ex which could maybe impact the sale???Would appreciate what owners thoughts are please.Thank you.
  12. Diamondpack joined the community
  13. 8520jason replied to tonydee's topic in 1984 to 1992 CRX
  14. 8520jason joined the community
  15. Iphone joined the community
  16. Hi guys, newbie here, had plenty of 1999-2001 civics enjoying the windows dropping, steering column loom failing and the CV boot’s costly repairs. However, rude as you like, seeking advice on an Aerodeck that has been in the family from new. Can’t get any proper info on these so wondered if I could get a link or two from the group on their history. I know they are quite rare now and dare I ask how much they are worth? Many thanks, Paul
  17. Must have missed this , nearly a year ago!! What do you use
  18. Earlier
  19. Hi Wuzhee, I have fitted replacement upper arms and adjusted them. On checking rear wheel toe, the nearside was showing it was toeing in. Worked out the 10 point nut has nothing to do with toe, its adjusted by slackening locking nut, item 1, then adjusting via item 2. Item 3 is an offset washer and fixed plate, by turning item 2 the offset washers contact with fixed plate 'moves' the arm. I setup a DTI and adjusting item 2 by approx 10minutes (on a clock face) I achieved 0.2mm change to the toe, where I was measuring it. I rechecked both rear wheel toe's and are now at a setting more in keeping where it should be, i.e. slight toe-in. For info turning item 2, near side arm, makes the wheel toe more in an outward direction measuring from the center point of the wheel facing forward and measuring off tyre wall. Im aware tyre walls are inconsistent in their shape however as the wheel was locked and the DTI remained fixed then a true reading was achieved. Thanks to everyone for their assistance to me.
  20. Hi Chris! The major cause of the inner tyre edge wear is due to extreme camber change caused by worn out bushings in the upper arm. The adjuster bolt-nut combo which goes through the back knuckle bushing does not contribute much to the wear, it affects the car's forward rolling behavior. There are several adjustable camber kits available, which solves the tyre wear problem. Hardrace Cheaper Noname Febest Left side Febest Right side
  21. clive joined the community
  22. 61Clank joined the community
  23. NWales joined the community
  24. Bakersone joined the community
  25. Hi thanks for the info esp tracking rear first.
  26. I adjusted the rear arms many years ago but were tough to loosen given where they are located so some effort may bew required to free them up. With four wheel alignment on this setup it is important to check and adjust from the rear first as a lot of operators adjust the front to compensate for the rear readings which is not what you are looking to do
  27. I would imagine it would last a great deal longer if the fluid and filter were changed in the transmission which quite often is neglected from service and maintenance routines
  28. definitely the wisest and cheapest repair
  29. a fine car throughout the years and the different generations of the CR-V
  30. Vehicle does not lock after walking away following option of right button. What page is it indicated otherwise? Ian
  31. Hi...welcome to the Club Fantastic car to own - haven't seen one on the road in years. Good to have you onboard
  32. The alternator will be engine ecu controlled also i think.
  33. It now needs the live data looking at. Just because its had an alternator and battery doesn't mean its necessarily charging. id be starting there first
  34. To clarify..... there is a 10 point nut on the rear lower arm, this provides adjustment for the rear Toe. Ive found the specs and on one occasion , during 4 wheel alignment it was adjusted. Can anyone provide any further information about the process, socket size etc. Direction of nut rotation vs toe in or out as I hope to be able to make this adjustment myself. Most other Honda's appear to have 3 bolts securing said arm. Thanks
