  2. I'm selling my Honda FR-V due to moving abroad. It's been well maintained and has a new MOT and full service history. PIctures won't upload here because they're too large, see advert on Gumtree. Located in NW London. Please PM if interested.
  3. Loved the adverts of the era as they were memorable - even after 50 years I can still sing the song that was played or the taste of the drink, etc.
  4. Yesterday
  5. Last week
  6. Steve Kernow joined the community
  7. colin setters joined the community
  8. Many thanks for the advice, the garage have sourced a new one so at least the car is still on the road. Is it alright to ask peeps what they think it might be worth if I were to attempt to sell it? Mum bought in new in 1998, 105k on the clock now and well looked after. Hope this is ok
  9. I seem to recall using a module from another manufacturer to resolve the parts supply issue at the time - could have been Rover or similar manufacturer that used the same system - at least it gives you an opportunity to widen the search. Searching by Part Numbers would be best to get straight to the correct part
  10. Hi Ivan....welcome to the Club I'm sure you will be pleased with the Jazz and its reliability and build quality Good to have you onboard!
  11. Hi this is Ivan here and I have just purchased a Honda Jazz Crosstar. Not had any Honda's before and at the moment very pleased with it.
  12. Hi all, does anyone have a working distributor or advice on where to buy one second hand or new as it has failed (garage diagnosed) on my sister whilst driving it Any help would be greatly welcome, the car is worth nothing if it isn't running :(
  13. Ivan Myles joined the community
  14. Oldboots091 joined the community
  15. I have found water drips from the air pressure vent ending up on the floor also. Have new one ready to replace and seal in! This is a 2017 CRV. Should add that I have been a CRV driver since 2005 and this is the first one to show a waterleak.
  16. SWSHondaCRV joined the community
  17. Earlier
  18. Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? Thanks
  19. Tyredguy joined the community
  20. Mike Kingfisher joined the community
  21. Any upgrade in bulbs is good in my opinion. Whether they bring a noticeable difference to the table may be good but unlikely to be any worse than the standard halogen bulbs
  22. Maybe worth increasing the pressures by a couple of psi to see if this extinguishes the warning. You can always let out some air but also good to check you don't have a slight leak on one of the tyres. Resetting the pressure settings on the vehicle may just be masking a fault in one of the tyres Also, ensure you check the tyres when cold
  23. paul turosak joined the community
  24. This warning light has come on, tyres are all at correct pressure as indicated by the indication just inside the drivers door. Is there a method of resetting.
  25. I have a 2018 crv, currently has 62000 miles. I've never been pleased with the low beam brightness. Its fitted with H11 55 watt halogen bulbs which look OK. Looking online I can upgrade to H11 exeon or H11 LED's, but both seem to be 60 watts, and a huge amountof lumins more. I don't want to dazzle on coming traffic but I do want to have brighter lights without having the need for adaptors. Has anyone changed/upgraded their lights. Alternatively is new halogens the solution? I've fitted blue bulbs in the past which I didn't think made much difference. Full beam is fine.
  26. GeofC joined the community
  27. Steve replied to Alan gsd's topic in The Lounge
    I used to love Jasper
  28. Steve started following Remember this?
  29. That appears to be the earlier version with single oxygen sensor that only measures earlier Euro standards emissions. The later version which is on the car measure both pre and post catalytic converter oxygen levels to compare and adjust feeling to optimise and measure the efficiency of the cat.
  30. Hi, I bought a new catalytic converter (this one: https://www.partsinmotion.co.uk/car-parts/exhausts/exhausts/bmcatscatalyticconvertertypeapprovedbm91585h-detail) and the mechanic told me it fits but sensor positions do not match, he added that this might make the sensor readings off and that I should get a different one. Has anyone had a similar situation? I was recommended this catalytic converter (BM) brand and I am not sure if I should get a different converter or just fit this one. Many thanks
  31. PeterC started following Honda FR-V Club
  32. Hi @Maurice j I have attached a PDF for you to look over to do some checks for your locking issue. Honda_eNy1_WalkAway_Lock_Troubleshooting.pdf
  33. I recently bought my Eny1 ,,,which I absolutely enjoy driving I noticed that the lock and walk away function was not working ... it locks the boot but not the car and both Honda tech support and my Honda dealer agree that it should but cannot resolve the problem Does anyone else have this problem? Maurice
  34. Hi....welcome to the Club There are still a few Aerodecks around but not many on the road. Spare parts especially panels are becoming harder to source but mechanically they are usually reliable as were most of the early models.
  35. Steve my son...... the world is your Lobster
  36. I am of age to 100% understand that... hit im terry 😂
  37. Arthur Daley is alive and well........ another nice little earner for her inddors Terrnace ny son !!
