Northernswimmer joined the community
- Christmas
DRL Jazz 2014 v-tec.
Most vehicles nowadays have the facility to retrofit accessories and most of it is in place from the factory (as in wiring loom, fuses, etc). If they car was taken to the dealer for retrofitting lights, etc then it is a case of fitting the lights, putting power to the lights (fuse, switches, etc) and then programming it into the CanBus system to activate it.
My 2014 Jazz is not fitted with Daylight running loghts, thinking of retro fit. Notice that cabin fuse box has pos15 labelled DRL, does this mean the car is wired for DRL ready for lights to be fitted. Any motor sparky help Thanks BB
Richard Larkins joined the community
1998 Civic Aerodeck 1800 VTI
Preventative Maintenance
Thanks again for your advice
gio joined the community
what is this? 2024 model
mihnea23 joined the community
Foster33 joined the community
Who remembers these?
Hi all, does anyone have a working distributor or advice on where to buy one second hand or new as it has failed (garage diagnosed) on my sister whilst driving it Any help would be greatly welcome, the car is worth nothing if it isn't running :(- Water in boot MK4 CRV
