Christopher Anderson joined the community
Zappa charger tells me the battery is full when it’s notLaurence started following Zappi app tells me the battery is full when it’s nLaurence joined the communityStuartwb joined the community- Last week
Northernswimmer joined the community- Christmas
- DRL Jazz 2014 v-tec.
Hi all, admins delete if inappropriate, either way thankyou for your help and advice. Up for grabs here: 1998 Honda Civic Aerodeck 1.8 Vti for sale | eBayBrian Baker joined the community- Preventative Maintenance
I'm not aware that these components would in fact fail due to inherent faults and are not necessarily maintenance items. The turbocharger is best maintained by ensuring the air filter is in good condition and also the engine oil is of the correct grade and quality.gio joined the community- Preventative Maintenance
My CRV MK3 2.2 DTEC has done 150000 miles. It has original clutch, water pump, turbo etc and a full Honda main dealer service history. I want to keep this car as long as possible. Which preventative part replacements should I consider doing to get another 100000 miles out of the car?John Marston started following Preventative MaintenanceJohn Marston joined the community- what is this? 2024 model
I would be tempted to top it up and see if that changes the reading and especially when it gets down to this level againmihnea23 joined the community- what is this? 2024 model
Hi all, does anyone have a working distributor or advice on where to buy one second hand or new as it has failed (garage diagnosed) on my sister whilst driving it Any help would be greatly welcome, the car is worth nothing if it isn't running :( - Zappi app tells me the battery is full when it’s n
