Sounds like a classic case of DIY ingenuity! Sometimes it's those creative, "not by the book" fixes that end up being the most satisfying. Love the rubber grommet idea to keep it tidy—definitely a cleaner look than just Blu Tack alone. Bodgit solutions for the win! Regards: كارتي
Z-Man98 joined the community
Mogweb joined the community
Gordy19 joined the community
Maarten joined the community
dearne75 joined the community
Angelov joined the community
