Rear Wheel Alignment FRV
clive joined the community
61Clank joined the community
NWales joined the community
Auto box life expectancy?
Gear shift gator
Histroy of the CRV
Histroy of the CRV
Hi. yes everything else works fine and fuses checked by myself and garage, its just those mentioned but it all started when the alternator went kaput and lit the dash up like a xmas tree. Yes, the car was told it had a new battery. i have disconnected the black wire on the battery many times, removed the negative cable from the battery many times. Tried the leave ignition on without running for 10 mins, cycle ignition thing 5-6 times without starting. The garage i took it too showed me the computer readout and it was green for everything. No faults showed up at all- Hi everybody
Do your interior lights come on when you open the doors? Have all the fuses been checked? It really needs to go onto a live data session to see what inputs the BCM is seeing. From what you've said it sounds like a problem with the BCM. You havent mentioned if that a reset had been done when the battery was changed. Also the battery management system might need a reset also. Could be why the stop/start isn't working. anybody with half a brain would be close to finding the problem on live data.OLSTERMEISTER started following Hi everybody- Hi everybody
Why has all the above been changed? Who has changed them? They're stabbing in the dark, mate.- Hi everybody
@OLSTERMEISTER civic dtec 1.6. new battery new alternator new battery sensor auto stop start still not working. car has been told it has a new battery. also almost around same time folding mirrors, electric windows and alarm wont work fob has new battery tried all the reset procedures for all the above issues. im almost a grand in on both problems and no one can fix it. any ideas?- Walk away auto lock function not working
My Eny1 is 18 months old and done 4300 miles The Honda on line brochure clearly states that when the right hand boot button is pressed the boot will close when you walk away and lock the boot and car The boot closes and locks but there car stays unlocked The Honda garage tell me that only the boot should lock and Honda Tech support confirm this HELP Does anyone else have this problem? Mauricerythecustomguy joined the community- 2014 Civic 1.6 Dtec
Hi all. thanks for the in. i have Civic 1.6 Dtec. Love the car hate the gremlins. auto stop start issues are killing me. £600 down with new alternator, new battery and now new battery sensor and it still isnt working properly. Very intermittent but mostly not working. car has been on OBD and there are no faults showing. Car has been told it has a new battery. Can anyone throw some light on this?Robdelnappio joined the communityMaurice j joined the communitygreen thunder joined the communityporgu joined the communityIanG joined the communitySean1981Civic started following 1981 Honda Civic- 1981 Honda Civic
Hi all, I have just inherited a 1981 Honda Civic Hondamatic 3dr in Shetland White with a blue interior. My grandad bought it new, grandmother took it on when he passed now left to me following her passing. Looking to get it back on the road properly following a video made by The Brake Show. Any help/advice/parts is greatly appreciated. Thanks, Sean- Auto box life expectancy?
OK, so mine's done 113k, what's the highest on here?- Another great one !!
Evening all We all know these cars are incredibly reliable, but I suspect the weak link is the auto box. Anyone any idea as the the expected life expectancy, assuming scheduled fluid changes, no towing (not that I expect many people would try to tow anything given the limitations of the petrol/auto combination...) etc? Thanks, RobChrisTopper started following Rear Wheel Alignment FRV- Rear Wheel Alignment FRV
Hi, my vehicle is suffering rear inner edge tyre wear. I am aware there is some adjustment that can be made on the lower arms, my question is - is there any adjustment that can be made to rear wheel alignment. I believe that the 'adjustment ' nut impacts on the rear camber and is adjustable for each wheel. Anyone can provide some more information on the subject or point me in the right direction ? My vehicle has clocked up 145k miles and has always been a bit heavy on rear tyres, even after 4 wheel alignment at a reputable garage chain, in fact on that occasion an adjustment was made but insufficient adjustment to be within tolerance. The cars history is known and no accident damage that could account for my problem. BTW the car drives fine and handles well in any weather, its just I fancy having a go at getting it to be more gentle on tyres. Thanks Chris.- Gear shift gator
It's has done well for 20 years so a hole about the size of a pin head is good going, so think my spot of glue will do the job for now. - Walk away auto lock function not working
