  2. things seemed so much easier back in the day - as long as the tyre was round then it was fine šŸ™‚
  3. I think some of them are making a revival - at least in name though Lost too many good brewerys over the years (Ringwood Brewery my local one has now closed) :-(
  4. Earlier
  5. Alan gsd
  6. These Mk 3 Jazz's are a bit posh tyre senors, remember the good old days when every garage air line gave a different reading!!. Had a damged tyre valve yeras ago was a late at night broken at the base used superglue got me home!!!!
  7. The same as when driving, tyre pressures increase on their own in hot weather. I don't know if the tyre pressure alarm points can be altered in the car to allow for the extra pressure in the tyres ( I'm not overly familiar with the Jazz as it's my wifes), but if not then you could physically lower the tyre pressures by a couple of lbs to stop the alarm showing. Don't forget to increase the pressures when the weather cools down. There should be enough leeway in the settings to allow for some variation in pressures.
  8. My Mk 3 Jazz tyre pressure sensors have been activated frequently in the recent hot weather . A bit of a nuisance . Any suggestions please ?
  9. It should fit the apeture but Halfords stock kits to ensure the wiring and fascia are suitable
  10. I agree with you Alan, it was by far the best of all the generations so far
  11. Finally found the problem. It was my passenger’s rare ABS sensor, which had debris and was cleaned properly. All warning lights never came back.
  12. I liked my Volvo's and Transit's but my first Honda a 2005 CRV is without question IMO the best car ever. The extras and finish is just the best
  13. It's https://www.ebay.co.uk/itm/197475366333?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3De6234bdbf97d43278ddcbf9164e6c802%26pid%3D101224%26rk%3D4%26rkt%3D5%26sd%3D205606678374%26itm%3D197475366333%26pmt%3D0%26noa%3D1%26pg%3D2332490%26algv%3DDefaultOrganicWebV9BertRefreshRankerWithCassiniEmbRecall%26brand%3DHonda&_trksid=p2332490.c101224.m- It's not mine for sale!! you could ask the guy in Doncaster the same question hahahahaha
  14. Yup. Why can't you send me yours with a courier?
  15. There one in Doncaster as well, cheaper but you have to pick it up. Thin kit was under £40. What's that about 60 odd miles from you.
  16. Thanks 😊 expensive though
  17. https://www.ebay.co.uk/itm/205606678374?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20220405142716%26meid%3Db6b4f406ffa44c468100442c1b24f502%26pid%3D101506%26rk%3D4%26rkt%3D10%26sd%3D197475366333%26itm%3D205606678374%26pmt%3D0%26noa%3D1%26pg%3D4481478%26algv%3DDefaultOrganicWebWithV11WebTrimmedV3VisualRankerWithKnnV3AndUltBRecallAndCassiniEmbRecall%26brand%3DHonda&_trksid=p4481478.c101506.m1851 Hi b4u2. if you are stil looking for a table this is on ebay £68 includng postage Alan
  18. Hi, I recently changed my Honda civic 2020 battery and after some hours my Amber warning light pops up so I took it to a battery specialist to make sure the battery was a good fit and all seemed fine so I was then advised to remove battery connections for 10 minutes so it restart everything things but Amber warning light still pops up at random but car seems to drive pretty well and I’m worried whenever light comes on
  19. Anyone fitted and wired a Android replacement Head unit to their MK2 CR-V ?
  20. More than likely this is the DPF regenerating and while that is active then possibly it will not allow the service reset to occur at the same time?
  21. wasn't sure what the arrows surrounding the spanner meant so looked it up: AI Overview The image displays an icon representing a wrench encircled by two arrows in a cyclical motion This icon typically symbolizes: Settings or Options: The wrench often denotes tools or configurations, and the arrows can imply a refresh or update of these settings. System Maintenance or Repair: It can indicate an ongoing process related to system checks, repairs, or optimizations. Automatic Updates or Synchronization: The circular arrows suggest a recurring or automatic process, potentially related to software updates or data synchronization. Loading or Processing: In some contexts, it can signify that a system is busy processing or loading information, particularly when related to system configurations or background tasks
  22. Trust you put the problem into good old Youtube?? There is bit on there about restting the service indicator
  23. Hi all, My car used to display an orange spanner symbol in the centre part of the Speedo clock when it needed a service. After servicing the car I could always reset the counter. But recently I notice that the service counter is blank (3 dashes) and doesn't appear to be counting anymore. Is there a way of re-activating it as I'm concerned it also has a link to the DPF regen system?
