DRL Jazz 2014 v-tec.
My 2014 Jazz is not fitted with Daylight running loghts, thinking of retro fit. Notice that cabin fuse box has pos15 labelled DRL, does this mean the car is wired for DRL ready for lights to be fitted. Any motor sparky help Thanks BB
Richard Larkins joined the community
1998 Civic Aerodeck 1800 VTI
Preventative Maintenance
Thanks again for your advice
gio joined the community
what is this? 2024 model
mihnea23 joined the community
Foster33 joined the community
Who remembers these?
Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? ThanksTyredguy started following Need to replace the Fuel Preasure Regulator & Sensor- Dim low beam
