Hi everyone, I’ve noticed an issue with my Honda CR-V Diesel 1.6 i-DTEC while idling. The instantaneous fuel consumption fluctuates significantly, pulsing between 0 and 20 liters, even though the engine RPM remains stable. This behavior has me puzzled, and I’m wondering what might be causing it. I’ve considered factors like the ECON mode, auxiliary systems, DPF regeneration, and potential sensor glitches, but I’m not sure if these are the main reasons. Does anyone else with the same model experience this issue? Are there known solutions or insights into what might be going on? Any advice or shared experiences would be much appreciated—thanks in advance! - Last week
Angelov joined the community
Jezza_speedandpower joined the community
CRJ joined the community
Des Roberts joined the community
Majid Ali started following New Member
Majid Ali joined the community
Hello, I live in Cornwall and recently acquired a 2012 1.4 Honda Jazz. I had a couple of Accords back in the 80’s and quite a few Honda bikes.
cnikonpete joined the community
Hi Tiz, have you looked at these ites?? https://hondaspareparts.co.uk/collections/discontinued-parts?srsltid=AfmBOooXh0sPT4xdU8LmRqY3qqXYnlAdsMZQs1kzkyU7VYgAjns1oGDl https://www.parts-honda.uk/
Honda claim that only genuine honda 0W-40 should be used on the CVT transmission, stating that non-geuine oils can adversely effect the operation of the transmission. Is this true & if so where can the genuine fluid be purchase ata sensible (i.e non-Honda) price? Thank you
Hi, I wonder if anyone can help please? My mum has had her Honda Legend since almost new and an ABS light has just come on. Apparently, it is the rear, nearside one and the part number is 57475-SZ3-010 i went onto EBay and put the reg number in. A different part came up, but it said it was compatible. Unfortunately, when I took it to the garage, we found it doesn’t fit and now too long ago to return! Honda say it’s been discontinued, as do some other sites. The car is in such a great condition … it’s only done around 58,000, so it’s really frustrating to have this problem in sourcing the replacement part. I thought I’d join your Group and see if anyone can help please? Thank you. Tiz
Colin Barron replied to Colin Barron's topic in Honda General Discussions
BTW I eventually realised that the mystery symbol instructs the driver to press on the brake pedal before turning on the ignition and starter. So it is nothing to do with the problem.But I would still welcome comments on my non-starting problem. -
Dear Members, I am looking for some advice.I have a 2019 Honda Civic VTEC 1.0 litre, 3 cylinder petrol automatic. No problems until two days ago. To explain - I am currently unable to drive due to a medical problem but should be resuming driving on May 7th (7 month ban). In order to stop the battery going flat I have run the engine (with car stationary) every 3 weeks for 15 minutes. Two days ago I tried to start the car. It would not start and I thought a nearly dead battery was the problem. I trickle charged the battery for 24 hours and tried again today. Dash lights up and starter motor turns but engine will not start. Any suggestions on likely causes and solutions. I have ordered a jump starter battery pack device from, Amazon but will not arrive until tomorrow. I have attached symbols which show on instrument cluster.
