Ruthless joined the community
Just for info, purchased a steel wheel and tyre from The Wheelshop in same size as OEM. It fits into the spare wheel well fine, but only just height wise. - Earlier
yvette joined the community
Z-Man98 joined the community
Mogweb joined the community
Gordy19 joined the community
