Chippyminton joined the community
Laurence started following New Members Introductions
Christopher Anderson joined the community
Zappa charger tells me the battery is full when it’s notLaurence started following Zappi app tells me the battery is full when it’s nLaurence joined the communityStuartwb joined the communityNorthernswimmer joined the community- Earlier
- Christmas
- DRL Jazz 2014 v-tec.
Hi all, admins delete if inappropriate, either way thankyou for your help and advice. Up for grabs here: 1998 Honda Civic Aerodeck 1.8 Vti for sale | eBayBrian Baker joined the community- Preventative Maintenance
Hi all, does anyone have a working distributor or advice on where to buy one second hand or new as it has failed (garage diagnosed) on my sister whilst driving it Any help would be greatly welcome, the car is worth nothing if it isn't running :( - Zappi app tells me the battery is full when it’s n
