Kunal joined the community
bignappa joined the community
GazB joined the community
CheScot joined the community
Thanks 😊 expensive though
Hi, I recently changed my Honda civic 2020 battery and after some hours my Amber warning light pops up so I took it to a battery specialist to make sure the battery was a good fit and all seemed fine so I was then advised to remove battery connections for 10 minutes so it restart everything things but Amber warning light still pops up at random but car seems to drive pretty well and I’m worried whenever light comes on
