Z-Man98 joined the community
Mogweb joined the community
Gordy19 joined the community
Maarten joined the community
dearne75 joined the community
Angelov joined the community
Jezza_speedandpower joined the community
If the symbol disappears once you have the brake pedal depressed then no problem but if still illuminated then could be a faulty pedal switch - try pressing harder on the brake pedal as well
