Alison S joined the community
graham Davies joined the community
470bhp joined the community
markosias joined the community
robbie3 joined the community
leedschap joined the community
Ali joined the community
I have a honda civic 2014 and recently warning lights have started coming on while driving First the car wouldn't start so I changed the battery which rectified the problem however after driving around 10 miles the warning lights reappeared Alternator is good this is charging the battery, all fuses good also, so not sure what this could be Any ideas would be much appreciated
fizzycheese joined the community
Benny joined the community
Thanks for the reply,but sorted now -
Can only find two listed - Fuse 3 (20 amp) in dashboard fusebox -
Trevor replied to Eban1969's topic in Jazz 2001 to 2008
Hi Eban Only the rear caliper pistons should need winding back - the fronts will just push straight back in. Usually best to release the bleed nipple when retracting the pistons and topping up afterwards. Makes it easier to push in and also removes the fluid that has sat in the caliper which is required to refresh the old fluid every so often. In addition, it does not send fluid back through the system in reverse which can sometimes (but now quite rarely) flip the master cylinder seals and also cause damage to the ABS hydraulic system. The clunking sounds like a worn CV joint which is causing the noise. -
Thats £82.50 per tyre and very good for Avon.....great tyres! Have just fitted Avons to my motorbike and shame they have only just now stopped making them in the UK 😞
HaHa.....that is absolutely brilliant and must have been fun to make 🙂
WHICH MOTORING MAGAZINE ON HONDA CRV
Trevor replied to BAZZER RN 1's topic in Honda General Discussions
I hope it reads positively? Which I'm sure it does as Honda have always boasted high safety standards -
Hi....welcome to the club! Yes, Lexus have been very slow to respond to the security threat and I think this has put a lot of people off from buying one....especially now the insurance is increasing because of the thefts I don't personally think it is too much of a problem with Honda, maybe the thieves find them a bit boring to steal 🙂 Superb choice of powerful cars prior to the Lexus and now the Honda Good to have you onboard
Hello, This may be an obvious question, but are UK / US engine parts interchangeable? I'm helping a friend with a head gasket change, and I can't seem to find a 1.6L head gasket on rockauto, and I'm not sure where to find a reputable vendor. The websites I've tried have been decent, but nothing I feel confident in buying. He has a 2006 Hatchback, 1.6L, for reference. I would appreciate any advice you could share, as your personal experience means a lot! Thanks, Caleab
Smoke coming out of the exhaust 4 different times as I was driving I would feel the car go a bit ruff then smoke foot down smoke and a bit limp or missing then after 30 seconds to a minute it would go back to normal fine for a few weeks then same thing no engine lights or codes then today service and MOT emissions perfect but the oil level on the dipstick was higher than it should by about 3lt even though nobody had put any oil in since the last service and MOT and still no lights or codes
Found the issue of a brand new battery drain after 2-3 days . Being the fuse for the interior lights and the radio - not looked into yet due to the weather only removed the fuse as a temp fix. As far as i know all the interior lights work correctly and so does the basic stereo . What could i be looking for as the issue draining the battery. 2007 honda accord 2.0 155bhp saloon
Hi Fred, Sorry for late reply, if I remember correctly that Honda had a recall on the Drivers Air Bag problem causing the light to come on, it might be worth contacting Honda Main Dealer to find out about this recall, Hope this helps BAZZER RN 1
Glad you got it sorted Alan its always worth remembering to shop around and please Guys, If any other Members on the Forum find any good value news or offering genuine discounts for Honda Members, Please share it on this Forum for others to take advantage of , Always make sure its a genuine offer from a reputable Company before committing yourself to any purchases Good Luck to All BAZZER RN1
I checked Green Flag out who I found out are Motoring Assit offered me a good range of services for my car and the wife's for £16 month.. Job done!! Phoned RAC to cancel been with them 22 years bear in mind my renewal went from £29.50 to £46.99 and after a phone call last week went down to £31.00 they start talking about going down lower if I stay, I stopped the guy and said I knew he was doing his job but not to insult me with offers when the powers that be at the RAC would have been happy to screw me for £46.99. Asked him to get one of the 'top people' to call me so I could tell them my thoughts. There's no reward in being loyal these days and if you are they play on the idea that you won't leave. Alan
2006/7 accord tourer diesel Having difficulty locating the rubber seals near me...Crewe. Any suggestions, alternative solutions etc Thanks
Hi squint68 You can place an advert in the Cars For Sale section of this forum if you wish
This I believe would be one for the Administrators to answer
Hi Alan I am getting emails practically each day from the RAC with offers of £ 7.50 each month for Breakdown Cover , I used to be with the RAC but am now with a company called Motoring Assist, might be worth you checking this out before renewing BAZZER RN 1
