Sorry can't remember which fuse I tapped into but had to use a multimeter to find a suitable feed that was ignition switched or permanent (depending on what route you want to go)
Have you tried a fluid and filter change which may revive the transmissions performance?
New battery drained... possible electrical problem?
Trevor replied to Johnny2Hondas's topic in 1982 to 1994 Accord
Sounds like the ignition system is being powered to the accessory setting on the key, I would check any relays and see if they click when they should and substitute like for like to see if it makes any difference to the clock display being permanently on -
Sometimes it can be a tough one to diagnose. The best way would be to attach a multimeter to the battery and then systematically remove fuses until the current drops then you'll know where the faulty circuit is located
Which engine does it have?
Does the battery need coding into the vehicle - e.g. vehicle may have to recognise new battery voltage otherwise will still be reading the old voltage If in doubt, worth checking to see if it has this function
Hi, I wondered if any advice on where I can find a silver front bumper for the first gen CRV reg 2001. Someone crashed into me and I cannot get a new part discontinued, or find and old one on ebay. Suggestions most welcome..Thank you
Andrew71 joined the community
Alison S joined the community
graham Davies joined the community
470bhp joined the community
markosias joined the community
robbie3 joined the community
leedschap joined the community
Ali joined the community
I have a honda civic 2014 and recently warning lights have started coming on while driving First the car wouldn't start so I changed the battery which rectified the problem however after driving around 10 miles the warning lights reappeared Alternator is good this is charging the battery, all fuses good also, so not sure what this could be Any ideas would be much appreciated
fizzycheese joined the community
Thanks for the reply,but sorted now - Earlier
Can only find two listed - Fuse 3 (20 amp) in dashboard fusebox -
Trevor replied to Eban1969's topic in Jazz 2001 to 2008
Hi Eban Only the rear caliper pistons should need winding back - the fronts will just push straight back in. Usually best to release the bleed nipple when retracting the pistons and topping up afterwards. Makes it easier to push in and also removes the fluid that has sat in the caliper which is required to refresh the old fluid every so often. In addition, it does not send fluid back through the system in reverse which can sometimes (but now quite rarely) flip the master cylinder seals and also cause damage to the ABS hydraulic system. The clunking sounds like a worn CV joint which is causing the noise. -
Thats £82.50 per tyre and very good for Avon.....great tyres! Have just fitted Avons to my motorbike and shame they have only just now stopped making them in the UK 😞
HaHa.....that is absolutely brilliant and must have been fun to make 🙂
WHICH MOTORING MAGAZINE ON HONDA CRV
Trevor replied to BAZZER RN 1's topic in Honda General Discussions
I hope it reads positively? Which I'm sure it does as Honda have always boasted high safety standards -
Hi....welcome to the club! Yes, Lexus have been very slow to respond to the security threat and I think this has put a lot of people off from buying one....especially now the insurance is increasing because of the thefts I don't personally think it is too much of a problem with Honda, maybe the thieves find them a bit boring to steal 🙂 Superb choice of powerful cars prior to the Lexus and now the Honda Good to have you onboard
Hello, This may be an obvious question, but are UK / US engine parts interchangeable? I'm helping a friend with a head gasket change, and I can't seem to find a 1.6L head gasket on rockauto, and I'm not sure where to find a reputable vendor. The websites I've tried have been decent, but nothing I feel confident in buying. He has a 2006 Hatchback, 1.6L, for reference. I would appreciate any advice you could share, as your personal experience means a lot! Thanks, Caleab
