  2. Hello Thanks for your reply Do you know when and how the 4WD kicks in please?
  3. I've just bought a new "24" plate HR-V Hybrid Advance Style which, according to the manual, has the Traffic Sign Recognition System fitted which can show both speed signs and traffic signs. However, the system only ever shows speed signs but never any traffic signs. The dealership cannot understand this and don't know how to fix it and a query direct to Honda UK unhelpfully tells me to go back to the dealership. Has anyone any knowledge of this issue or whether it is still an active system?
  4. Last week
  5. Hello Paul, welcome to the club. Below is part of a report by 'What Car' I have a CRV same year as yours and find it a great car but I don't take it off road. I did know a guy who owned a Ranger Rover who got who got stuck all the time, turned out he had the wrong tryes for off road work. What's the used Honda CR-V estate like? The CR-V is more a pumped-up estate than out-and-out off-roader. In fact, 4WD only kicks in when it's needed, so for the bulk of the time, you're driving a front-wheel-drive car. In other words, and as Honda will admit, this is basically a road car with some (very limited) off-road ability. That means, with no awkward compromises to strike between its on- and off-road abilities, the car can concentrate on one thing - and so it does, to tremendous effect.
  6. This won't help much, but just wanted to say that in terms of obtaining parts for these (depending on what you need) it is rather tricky at times. For example, none of the scrapyards within 30 mile radius of me have any of 1st gen crv's in stock. As you've mentioned some parts are discontinued. The only hope is to keep checking eBay until something pops up, or find someone who is breaking one up for parts, but that would be eBay as well I suppose. Good luck.
  7. Not yet, although it is on the to do list. Lack of time is a factor. Though the transmission is changing gears smoothly and there is no clonking when engaging gears. When I eventually get round to changing the fluid I will put an update up. The fluid itself does not look too bad. It is not new, I can tell that much, but not too bad. Is the filter actually a serviceable item on these transmissions, or can you only access it when you are rebuilding the gearbox?
  8. it would be very helpful to have a picture of the windscreen washer pipe layout under the offside rear floor well. Two elbows I believe?
  9. Hi everyone New member here, hello! I have purchased this car to be a farm run around in a field, pulling a trailer, roller etc. The car is 4WD (a key requirement for me when buying) but this appears to be ‘automatic’ rather than engaged through any controls on the dash. On its first outing the car got stuck in a muddy field very quickly and it was not easy to get it out as it got stuck every time it was freed again until it was virtually back out the field. I had done some research before buying and saw people off road with their CRVs and some very steep hills so I am disappointed with my experience to date. Have joined the forum to understand more about the 4WD aspect of the car and its operation, tips for driving etc. Any responses appreciated and thanks for reading. Paul
  10. Hi all again. I have this annoying shudder when starting off from stopped. It only lasts a second, then is gone, until your taking off from being stopped again. The car runs perfectly at all speeds in every other way. If it were a manual car, my first guess would be to think it would be the clutch, or as its a 4 X 4 prop bearings. May be significant, but it only does this after it has been running at least a few minutes, perfect when stone cold, no shudder/judder. I am going to try and discount the gearbox, by having a fluid and filter change. If that has muck in it from 86000 miles of use, (no evidence the fluid has ever been changed) that might mess around with the oil pressure and influence the take off. I will report here again once that has been done. Is there any way I can electrically disable the 4 x 4 for testing to see if its that, which is making the shudder? If anyone has had the same type of problem, please let me know what happened, and how you fixed it. Also if you have any ideas please let me know. Anyway, thanks for reading this, and any help would be greatly appreciated. Eddie
  11. That's great to hear, thanks for letting us know.
  12. Thanks for your reply Trevor, in the end I just winged it. I chose two vacant fuse holders after looking at the layout and it worked. Switches on /off with the ignition so I'm happy. Luck of the Irish I suppose.
  13. Sorry can't remember which fuse I tapped into but had to use a multimeter to find a suitable feed that was ignition switched or permanent (depending on what route you want to go)
  14. Have you tried a new (quality) battery as if the old one needs charging periodically it may have faulty cells and this can cause the issues you are describing (if the battery cannot deliver a high enough voltage on start up then this will flag the lights)
  15. Have you tried a fluid and filter change which may revive the transmissions performance?
  16. If you decide to sell it then you are welcome to advertise it in the Cars For Sale section of the forums https://uk.hondaownersclub.com/forums/forum/58-hondas-for-sale/
  17. Can you not get them reconditioned.....I'm sure there are still some companies that can do this service
  18. Sounds like the ignition system is being powered to the accessory setting on the key, I would check any relays and see if they click when they should and substitute like for like to see if it makes any difference to the clock display being permanently on
  19. Sometimes it can be a tough one to diagnose. The best way would be to attach a multimeter to the battery and then systematically remove fuses until the current drops then you'll know where the faulty circuit is located
  20. Which engine does it have?
  21. Does the battery need coding into the vehicle - e.g. vehicle may have to recognise new battery voltage otherwise will still be reading the old voltage If in doubt, worth checking to see if it has this function
  22. Hi, I wondered if any advice on where I can find a silver front bumper for the first gen CRV reg 2001. Someone crashed into me and I cannot get a new part discontinued, or find and old one on ebay. Suggestions most welcome..Thank you
  23. My dad is looking to sell his much loved Honda Civic Aerodeck V Tech X reg, 55000 miles. New clutch and tyres. Would anyone be interested?
  24. Earlier
  25. can anyone help me find the radio code. details in pic.
  26. Hi All, my fob has died. I have changed the battery (checked it in my other fob it works fine) i can get a fob online or from a breakers yard ( i am not going to pay the £600 the dealer wants) but it will need to be paired to my car. Can i do this myself or not? You tube has been unhelpful!
