Hi folks, recently picked up a wee honda logo with an idle bounce at running temp. Wana replace the intace air control valve but having problems sourcing 1.
Any ideas or links would be appreciated.
Sorted the issue by cleaning the throttle body with some wd40 on a rag.
The eml lights came on and some black smoke which I'm guessing is the oil burning from the cleaning.
My new issue is the rad fan not kicking in. The motors fine as I did a direct feed from battery. Fuse is good and I swapped over relays with the horn which works. The temp gauge sits at halfway at running temp, I'll probably take out the thermostat next to see if that's working... Then it's either the temp sensor or the loom itself. Any other ideas?
