Hi all,
           Looking for a bit of help.  Has anyone fitted running boards ? I have a second hand set of genuine Honda parts and I have downloaded the fitting instructions which seems fairly straightforward. What I don’t have are the templates required to enable me to cut out access holes for the fitting brackets in the plastic underside panels. Can anyone help with this please, much appreciated
Rob
Below are some links I found on 4x4 Direct website which may shed some light on the fitting procedure
Up to 2012 - Fitting Guide (PDF)
https://cdn.shopify.com/s/files/1/0015/1502/8545/files/Honda_CR-V_2007-2012_Side_Step_Fitting_Instructions.pdf?17907606410955683975
2012 onwards - Fitting Guide (PDF)
https://cdn.shopify.com/s/files/1/0015/1502/8545/files/Honda_CRV_2012-2017_After_Market_Side_Step_Fitting_Guide.pdf?12855092772702160784
Thanks Trevor, much appreciated
  • 4 weeks later...
where did you buy after market ones rob?
