Honda accords cranks bit wont start
I have a honda accord 2003 uk model
Car cranks but wont start.
Can someone tell me where is the fuel pump fuse?
Or any other suggestions?
If there is a spark on the plugs then it may well be fuel pump related.
If there is no spark then I would be looking at the Crankshaft sensor as this generates the signal for both fuel and spark
Let us know what you find
Trevor
Thanks for your reply appreciated.
 There is spark, thats been checked. it had bump at the front and where the bonnet latches onto that has been pushed back by an inch or so.
Any other suggestions?
Ok trevor
Thanks for that. I have had a brief look but could not locate it. Ive checked it on the passenger side can not visibily see it. I think i may need to dig bit deeper by removing some panels. Ive removed the glove box no joy there.
Will let you know how i get on
Thanks trev
  • 8 months later...
Have you checked for Trouble Codes - you need a code reader and then find the socket on the car that it fits into / - might be a crank sensor - it would show as PO 335 on a code reader. Mike
  • 3 months later...
On 11/22/2019 at 5:31 PM, Type r said:
Ok trevor
Thanks trev
What happened then?
