Hi I have a Honda Civic 1907 brilliant car 👍 but there’s a problem with the electrics at the moment and I don’t know which route to go to get it fixed. It was suggested to me to try this forum as a start.
Basically on the dashboard the clock is only partly lit up, a lot of the time the windscreen wipers at times have a mind of their own and so does my key fob-which will work one day but not the next!
Has anybody else had this problem?
thankyou In anticipation ☺️
Sue here....Sorry 🙄 year 2007 🤦‍♀️
Hi Sue....welcome to the Forum
The first thing that comes to mind is the Battery earth terminal and leads.....make sure the terminal is secure on the battery and has no corrosion build up on the terminal.
Also check the leads and ensure both ends are secure and free of any corrosion.
After that I would check the battery condition and if good then you would have to proceed with individually diagnosis each electrical fault, but its always worth checking the obvious first and at no cost.
Let us know how you get on with it all
