samrani Posted December 11, 2019 Posted December 11, 2019 I have replaced my abs unit with a guaranteed used, all , bled and put back and tested as good. car does all it should but now the abs dash light is flashing instead of being fully on.... any ideas? cheers Sam 2002 Jazz 1.4 petrol
Trevor Posted December 11, 2019 Posted December 11, 2019 Is there anyway you could scan the system to see what codes are there....cheap scan tool or local specialist? Maybe a coding issue, could be a code that needs erasing from the memory, air in the system?
samrani Posted December 11, 2019 Author Posted December 11, 2019 Many thanks, for your reply, will take it a a mechanic for this. cheers 1
Register a new accountSign in
