Hi
My 2012 crv es model has blown fuse 10 (7.5 amp) 3 times, usually happens when turning right lose all dash info and indicators, if engine switched off it will not restart until fuse replaced.
Honda specialists couldnt find cause, and i am losing confidence in this vehicle.
Help please
Alex
if you had given what fuse 10 controls it might have made this a bit more simple.As you say that you loose your indicators,the side repeater is where I would start looking for
water ingress, followed  by the front and rear RH indicators looking for a fault in these,even in the lamp.Hope this might help as will a multimeter.Try looking on' you tube' for honda faults in general you might find the same fault listed for a civic or an accord.
According to the handbook no 10 fuse is for dials or meters
