Hi Folks
I would like to isolate the power to my driver door mirror to determine if the led indicator repeator is blowing my fuse no 10, as described in an earlier post, is there there a connector somewhere between the fuse board and door pillar.
Alamo
The only drawing I have is for a 2006 Honda crv,as there is no reason to change it ,it shows the repeater connected between the front and rear indicators,in parallel with them.If it is like other cars you will find a plug behind the wheelarch where the repeater is situated,you will need to unplug by pressing some sort of lever on the plug.Hope this helps.
