Hello and thank you for reading this message.
Battery frequently going flat in Honda Jazz 1.33cc 2012 plate.
New battery needed or may there be a fault? (NB there is a disused black box on top of the battery. The battery issue has been happening before the black box was installed.)
Thank you for your help.
Hi.....welcome to the Forum
Well it looks like an original or if not quite an old battery so chances are its no longer holding a charge.
A replacement would probably resolve the issue.
Not entirely sure what the box on top of the battery is but if in doubt you could disconnect it and see what happens but if new battery installed then probably okay left connected.
