Has anyone suffered water getting under their drivers floor mat.
the carpet is dry on its upper surface but wet underneath suggesting water is running down the bulkhead and under the carpet.
tried spraying talc onto floor mat but hasn't helped to show up whereater is coming from.
anyone any ideas please.
Are you losing coolant...e.g is the heater matrix leaking inside the car.
You would usually smell the antifreeze if this was the case.
Alternatively, if you can find a garage with a smoke generator machine then it is very easy to find the source of the leak.
