Noise from A pillar on O/S/F above 60mph
Hi. I've recently purchased a 2007 FRV automatic petrol and at around 60mph from the off side front A pillar area I am getting like a buzzing/wind noise from around that area. I've removed the trim and driven it again and it is still there so not a trim issue. It must be speed related as it does not happen below that speed on all types of road surfaces. Is there any issues with the windscreen seal or A pillar window seal. It  sounds like it's by the air bag area. Any ideas would be great. Many thanks and stay safe.
Hi. It's definitely not coming from the window/door seal. It's from the windscreen and little panel of glass area. Very frustrating as it only happens over 60mph so very difficult to figure out what is causing the problem. Thanks.
