Hi
I’ve a Honda FR-V 2.2 d , i have trouble some times with changing gear I have to pump the clutch pedal a few times and then all good,?? and my hand break light comes on and beeps have to pull out slightly and slide back in some times linked with above problem or if go over a bump like it’s lose ?? Anyone any ideas on these problems would be a great help many thanks stay safe
Hi...welcome to the Forum
The handbrake is more than likely just a case of taking up the slack on the lever by adjusting up the cable a small amount.
This usually cures the flickering light problem.
The clutch pedal sounds like it could have some air in the hydraulic system which needs bleeding out.
Let us know how you get on with it all
