The wipers stop working when switched to high speed on 2010 accord. Slow and intermittent are fine
Hi.....welcome to the Forum
That's quite strange as if it works on one speed or more then it should work on all the speeds.
I wonder if the speed sensing function is not allowing that speed to work unless the rain is sufficient quantity to justify it?
Thanks Trevor
Not sure about that, the wipers stop completely when switched to hi speed and dont even return to rest so thinking it could be the switch?
Same here, hence the reason for registering, how could this be fixed?
  • 10 months later...
