i have a 1996 honda accord aerodeck es auto 2.2 estate ,can somebody tell me where is the obd port ,it is not in the position of a normal 1996 accord ,thanks a lot john
thanks ,but its telling me its behind the ashtray,but that is for a 96 accord and this is a 96 accord aerodeck es auto estate ,ive never seen another apart from mine ,if you can locate it for me that would be great john
  • 5 weeks later...
not found yet ,can you help
Thinking about it Honda did use to hide the ECU within the passenger footwell (if you pull the carpet back under the dash and see if there is a plate there that covers the ECU.
Also, around that time they may still have been using flash codes which were blinking LEDs on the ECU which you then deciphered the meaning of the long and the slow flashes
