Hi all,
Ive got a 2012 CRV   It’s not been driven for a few months and when I took it out today I noticed a thudding noise when pressing the brakes. Like a du du du sound..   it ‘ seemed’ to be coming from rear passenger wheel area
Any clues as to what could be causing this? Is it an expensive garage fix.  I’m not capable of doing it myself...
T.I.A
Hi.....welcome to the Club
It is more than likely corrosion on the discs if it has been sat around for a while so just needs to be driven and eventually it will rub off the rust surface and return to normal
  • 8 months later...
Or the brake caliper is not retracting as it should (sticking )
