Hi Folks, great forum on here, and I'm hoping you guys can help me out, my question is, can I fit (the Honda factory fit) roof rails to an FRV that's doesn't have them?
i.e. I'm looking at buying an FRV currently choosing between two models; a 2006 (low milage) or a 2009 (high milage).
Im leaning towards the low milage 2006 model but I will need roof rails and the 2006 doesn't have them, so are roof rails somthing I can fit after the fact?
Thanks in advance!
Wow yeah looks like it's bolted in place, I have gone ahead and bought the the 2006 FRV, great car but needs some work, after I get the all clear from the Mechanic I'm gona take a little peak under the rood trim to see if there is mounting points and if so, I'm off to the scrappy to get a set of roof rails 👍
  • 5 months later...
Hi Anthony
Did you manage to grab any roof rails? They bolt on via mounting points. But you either need to get the gutter seals from the car you obtain the rails from, or cut your existing ones with a hacksaw.
