Rear passenger air vents.
Just purchased a 14 plate CR V and I've noticed the air vents on the back of the center arm vest are not moving. Is it an easy job to remove these vents? Thanks .
Thank you I will give it a go in the morning.
On 10/25/2021 at 10:02 AM, Trevor said:
They should pull out from clips.
May require moderate force but not enough to break unit
All fixed,a couple of the vanes had become dislodged and jammed. Easily removed and replaced with one vane needing a small screw from above to keep it in place. Thanks for the info.😁
