I am hoping someone can help me please, I have a 2012 Honda CRV and I have a DPF light with exclamation mark on, RAC said the car has already done a regeneration and doesn’t need a forced regeneration but the computer hasn’t realised and turned the warning light off. Has any one had any experience of this and any solutions. I took it for a DPF diagnostic and they said the light went off but came back on instantly. Any help would be greatly appreciated. Thanks
  • 7 months later...
Hi Sean, what was the outcome/solution of your DPF issue? I've got a mystery problem with mines at the moment, it's booked in at a Honda dealer after another garage failing to clear dpf fault.
After numerous garages failed to sort the problem I took it to a man I found on Facebook, it turned out it was a computer problem. I think he rebooted the system and cleared the fault and I haven’t had any problem since. If you live near the Sheffield area I can give you his name. I was also advised not to use cruise control anymore as this adds to the problem.
Thanks Sean. I stay in Glasgow so a bit out the way. I phoned Honda and they confirmed the car requires a software update (something to do with the exhaust emissions I think) so I'm hoping this is the reason it is not regenerating properly and clearing the fault. It goes in on Thursday so will update you on it.
  • 2 years later...
Hi Sean
Could you please let me know the name of the guy in Sheffield.  I live in Ripley, Derbyshire so not too far away from Sheffield.  I have had numerous diagnostic checks (no fault showing), no excessive soot, tried regens and an oil change but still the warning light is on.
Thanks, Alison
