Accord cu2 (2.4 ivtec) 2010
Halo to all
I have accord cu2 (2.4ivtec), and i have problems with ignition. Pump is working i can hear that, but when i starting engine it is imposible to start from first. I change sparks before 500km and nothing changed. When engine start, it works fine. There is no check engine light. I check ecu there is no some fault. When engine start there is drop of rpm, and than work fine.
Can someone tell me what is the problem?
In front thank you.
