Hi. Can't find a single pic or video for this. Anyone know where the knock sensor is on a 2013 CRV 2.0 EX please? Is it at the rear beneath the inlet manifold, does IM need removing 😞
A knock sensor is normally located on the side of the engine block and midway between cylinders 2 and 3 (unless there are twin sensors then they would be between the first two and last two cylinders)
  • 2 weeks later...
